Results 1 to 2 of 2
Thread: Speed Density not active
    Apr 2023
    Italy
    42
    In the map I found in the ECU the Speed Density was not active and all works on MAF mode
    It works quite well especially after I tune the MAF properly, but should I activate SD or not .....which in your opinion are advantages and disadvantages?
    thanks
    Paolo
    Grifun mid engined V6 3500 LZ4 manual trans
    Mar 2022
    Indiana
    3,002
    High RPM Disable is still set to 4000rpm. That means at 4000rpm and below dynamic airflow calcs reference both MAF and VVE. You should tune VVE also.
