Results 1 to 7 of 7
Thread: 2004 oxygen sensor code list?
    Feb 2024
    2
    Probably a long shot. I have a 2004 5.3. I'd like a list of all codes related to the downstream. Sensor 2. Oxygen sensors. And catalytic converters.
    LS swap in older, non emissions regulated vehicle, no downstream sensors or cats. with functional CEL. Soon as one dtc gets turned off another appears out nowhere.
    Thanks.
    7,648
    OK, here's your list:
    - Any DTC with 'Bank something Sensor 2' in the name
    - Any DTC with 'Catalyst something' in the name
    Scrolling through the DTCs and reading each one's title will be a lot of work, but you can do it. I believe in you.
    Mar 2022
    Indiana
    2,944
    xD
    Feb 2024
    2
    I can tell you felt pretty good about your response. Unfortunately you assumed too much.
    Appreciate the sarcasm though.
    I have a tuner (im not the tuner) that uses hptuner and is animate, about only removing dtc's, the customer specifies.
    I've asked for the rear 02s to be removed multiple times, the current dtc does get removed but for reasons I cannot explain, it seems a new dtc appears weeks later, related rear 02's.
    I hoped to avoid future issues and provide him that list.
    If your unaware of such a list, that's ok.
    What gave me the inspiration to ask. Is upon many searches, I had found posts with such lists but unfortunately, unrelated to my engine.
    7,648
    Nobody can see what is in your tune file from your vehicle unless somebody reads it out and you post it here.
    Mar 2009
    Andover, MN
    457
    Get a new "tooner" if he is incapable of an "offroad" tune.
    Nov 2017
    1,466
    Edit software is free. Tuner can send you the tune. You can still read through the list yourself. But your tuner must not know what he is doing.
