Results 1 to 10 of 10
Thread: nag 1 not responding to shit adjustments
    Tuner in Training SDCE's Avatar
    Nov 2010
    East Providence, RI
    32
    shifts at 5900 no mater what i do .
    it also upshifts at 5900 in autostick.
    It is a new trans and engine ,engine makes 650 hp at 6800 rpm na.
    if i do by chance get it to 6500 the trans goes in limp mode( all neutral)
    the tq reduction on shifts is also random it seams to work below 5400 rpm but not above .
    does anyone know why various rpms and other data on data record do not match for example vss on graph is 71 on channels it is 67?
    Tuner in Training jefo's Avatar
    Jul 2022
    33
    Noticing some things that may fix your issues:
    Engine Side:
    -Engine rpm limiter is at 6850rpm, you want this ~400rpm above the TCM limit (Currently TCM limit is 7500rpm). Raise the engine rpm limiter to wherever comfortable, and have tcm limit 400rpm lower.
    -Tq mgmt Shift TqRed Time is 0 -> change to 0.30s
    Trans Side:
    -Modify TCM limit as stated above
    -Limp offset is 500 -> raise to 1000
    -Perf Driving Factor is off? Why is this?
    -Max shift time is 0ms -> change to 2400ms
    -Converter lockup in 3rd is at 7050rpm and 4th is 6100, with unlock rpm higher which is strange (unlock rpm should always be lower than lockup rpm)- maybe it doesn't matter though in this case, but its worth fixing.
    Try changing those to see if it solves your issues. Is this a stock NAG1?
    2006 AWD 300C Turbo - stock 5.7, stock NAG1
    10.8@126mph on 12psi - WatTuned
    Nov 2010
    East Providence, RI
    32
    the perf driving factor is off because i did not another influencing factors to be at play .
    The shift time was a type o i did notice that .
    The converter stuff is weard it is like that on the stock call . i think it is so the converter is always locked .
    Stock the trans limit was 6400 limp was 500 whitch should be hi enough .
    Does the code not recognize 7500
    It is a new trans with blue top amg solinoids.
    Nov 2010
    East Providence, RI
    32
    I was able to keep the trans out of limp mode by setting the limp offset to 7500.
    stoll cant get to shift past 6000 or so .
    the 2 data records here 1 is set to 3125 the other 3225 for the 2 -3 shift b the it shifts the same .
    i also noticed that the wot flag is off at wot . the trans throttle reports 100%
    Jul 2022
    33
    Post
    I checked further and your down shift scheduling was wonky as well. Downshifts higher than upshifts. I fixed this as well as the converter unlock rpms. You changed the max shift time value, but it is still too low - this is not the proper way to adjust shift speed. And I made some other changes like engine max rpm changed from 6850 to 7000.
    Try flashing this Engine/Trans file and report back; It should shift right around 6700 for each gear.
    Nov 2010
    East Providence, RI
    32
    I will try today .
    About the downshift table with the 2-3 set to 2150 oss should mean it will not downshift till the oss is below 2150 which in 3rd gear is 3050 rpm . this is how i understand oss shifting , is this not correct ?Iin IN 4 and 5 the downshifts look like normal gm tables .
    This shifting on oss is weard , vss is way easier to me .
    Jul 2022
    33
    The downshifting is one gear offset from what you are thinking. For example the 1-2 and the 2-1 are both based on the 1st gear ratio. 2-3 and 3-2 are based on the 2nd gear ratio, etc.
    Nov 2010
    East Providence, RI
    32
    I tried your set up ,it shifts softer and slower but still shifts at around 6000 .
    Jul 2022
    33
    I can't see the log file as I have the old software, but yea the tune shouldn't have fast shifts as it's basically stock, but it should shift higher.
    It still shifts at 6k? Strange
    Jul 2022
    33
    Arrow
    Try this one - be sure to flash both engine and trans cal. If it still shifts at 6k, then I'm not sure what the issue is.
    Trans shift points are set at 6800rpm.
    Changed torque converter lockup in 3rd gear +
    Shift firmness/speed upped
    engine rev limiter bumped by 200rpm
    some adder values, max torque, and torque management changed
