Thanks to bindsquirrel and sirius for introducing me into filtering in the scanner.
Below is a scan, and three sections in the 'graph' area that are all the same, but error 1 has one type of filter, error 2 has a compbined filter, and error 3 has no filter.
I'd like to "Add a filter to remove all the data that's not EQ = 1 (e.g. open loop warmup/PE).."
And also used the picture attached below.
My quesiton is, how do i know what each filter does? And yes, i have read the hptuners instructions, and i see the filtering section, but, is there anymore indepth instructions on the topic? There is very little info here in the forums, and some of that info is well over 10 years old, and the instructions or pictures are outdated and dont work.
Seems to me filtering woudl be a big help, I'd just like more info to fully understand the topic. For example, what does EQ =1 mean?
And if I am way over analyzing this, sorry, i like to know every detail. I look at it as, hptuners is a tool, if i dont fully know the tool and how to use it, then it amkes me look dumb in the end.
thank you.
