hey guys!
I'm defiantly still in the learning stage for tuning.. I've had multiple people help me along the way, this last tune file I've come up with from a very helpful guy in Michigan I've gone from 21# injectors to 12613411 stock used injectors, which I'm hoping are still good... we have recently tried to set it up for the more fuel in the engine to try and get a bit more power and smoothness out of the engine.. but it seems somehow we went backwards with the tune file? i have a few scans and files saved, is anyone able to point me in a direction to start adjusting? i think maybe more fuel? defiantly trying to keep it as low rpm and as smooth as possible for offroad.. is there a way to test for a failing injector?
ls yj justin final 36lb injector.hptbigger toodle w no wire adapt feb 10th.hpl
89 yj with a 99 LS 6.0 , 799 heads, BTR TN cam, headers, CA intake, 4l80e 1600 stall.60 psi rail pressure return less line, self regulating. high flow filter with performance pump. used only as a snow wheeler on long offroad trips fuel milage is important lol..
