truck runs lean about 18.0:1 AFR for about 30 sec at startup hot or cold. After 30 sec truck idles +-14.7:1. What tables should I adjust to fix this condition?
'99 silverado 2500 4x4, 408, inlet forward MP122HH, 60# mototrons, borla exhaust, HPT 2bar OLSD
I see you are OLSD, have you checked your histogram #7 to see what ve cell you are during the lean afr readings? it could be that one or two of your ve cells are set to lean since after 30 seconds or so you afr comes back in line, you could now be using a different spot in your ve table. just a guess though....
2003 Silverado SS -6.0L - 4L65e - AWD
2008 GMC Sierra CCSB - All stock
2011 Chevy Traverse
I'll check that out.Originally Posted by Holty
Turn off your AIR pump and see if that goes away.
No A.I.R.Originally Posted by jimmyblue
in SD it is typical to see lean hot starts, search and you will see.
Sulski Performance Tuning
18:1? It RUNS at 18:1?
16.5 or 17 :1 is pretty much the limit in terms of flamability limits as far as I've ever seen in real life.
03 Silverado
Go faster: LQ9, 4L65E, Catback, long tubes.
Pretty: Billet Grille, Helo Max 6, TerraGrapplers
it will run
runs lean off idle also. not as lean though. 18:1 at idle for 30 sec cold or hot.
thats odd it sounds just like the air pump kicking on, yet you dont have one you said
Is there some sort of start up or warm up enrichment that could be out of cal?
There are table for startup enrichement, but they dont generally cause a lean condition like that for an exact amount of time.
ever figure this out?
