Just a few PE questions. Here is a screen shot of my PE Tab with the ECM 12400 PE EQ table and the ECM 12420 Hot PE Enable TPS Threshhold.
Attachment 142802
This is bone stock and has not been touched.
Looking at the MAP and RPM enable, PE appears to be on at all times?
Is the ECM 12420 table an indicator of when PE is activated by TPS?
Also looking at the ECM 12400 PE EQ Ratio, Things seem awfully rich for a stock setup.
The peak torque area of my engine is roughly 4600 RPM and EQ is calling for 1.3 which equates to an AFR of 11.2:1
I can remember tuning a boosted V8 a while back and we were shooting for 11.7:1 AFR at peak torque with Max boost
I did not expect to see a NA motor this rich.
Am I reading this correctly?
I see the delay is set to "0" so I am assuming all the delay values dont mean anything as the delay is "0" and will never really be a delay?
