Results 1 to 16 of 16
Thread: LQ4 - Big Cam Tuning
    Oct 2021
    Neighbor put an LQ4 in place of his LM7 in a 2003 Silverado. He slapped a big cam (specs below) in it with no other mods and asked me to come tune it. I'm going to look at it this weekend, but based on the cam card, it looks like I have my work cut out for me. Any help on getting a tune close before going over there will be greatly appreciated. Thanks in advance!
    Lift: 0.595"/0.595"
    Duration @ 0.050": 234?/277?
    Advertised Duration: 295?/336?
    Lobe Separation: 107?
    Injectors are stock 6.0 replacement injectors - TRQ FLA60337
    Base tune attached.
    Silverado_stock.hpt
    7,649
    Your search - FLA60337 - did not match any documents.
    Suggestions:
    Make sure all words are spelled correctly.
    Try different keywords.
    Try more general keywords.
    'stock 6.0 replacement injectors' only narrows it down to about 8 or 9 possibilities. If you meant to say 'stock 2003 6.0 replacement injectors' then those are only 25lb-hr and not big enough for the power that combo would make. If the truck has a returnless fuel system those are only good for about 360 HP, at the crank. A 2003 truck should have a return style system, but your file is set up for returnless.
    Mar 2022
    Indiana
    2,954
    5BA8
    3,256
    Cam needs to come back out and go in the trash too. If those specs are right it'll never run right.
    email=[email protected]
    Arizona
    453
    especially in a big heavy truck
    1,467
    But it will sound good.
    5BA8
    3,256
    I'd like to believe the 277 exhaust duration is a misprint. If it's not that's just ridiculous. That much duration is typically solid roller type stuff and no one runs a 43 degree split. So, if it's a misprint which I believe it is, even if the real duration is 247, a 234/247/107 LSA is still a terrible choice for an otherwise bone stock truck. This is the kind of stuff I turn away. "Nah man, your combo is just dumb. Sorry". LOL
    Jan 2024
    49
    Not to mention piston to valve clearance with a split like that!
    Oct 2021
    Sorry guys, he sent me a misspelled injector PN - it's FIA60337
    Below is a link to the cam. Not a misprint, unfortunately.
    https://www.jegs.com/i/JEGS/555/200584/10002/-1
    I'm tempted to walk away. Really good guy, but the Jegs counter guy told him this was a rowdy cam good for a stock truck. Sadly, he believed him. Just found out it's on a stock TC as well, so even if I could get it to idle in P/N, there's no way it's going into gear.
    He did inform me that he has the 2006 6.0 ECU in it and the truck is a late 2003, so it was returnless. So, the returnless system is correct.
    Mar 2022
    Indiana
    2,954
    Throw the Jegs guy in the trash.
    405
    2,326
    Quote Originally Posted by stilsonian View Post
    He did inform me that he has the 2006 6.0 ECU in it and the truck is a late 2003.
    06 calibration is not compatible with 03-05 ETC hardware.
    May 2023
    Arkansas
    18
    It'd be faster with the factory camshaft.
    Dec 2019
    MS
    567
    This is the perfect example of when to explain to your neighbor to stop before it gets any worse. Im sure you can get it to fire up and halfway idle but your working with chineseium injectors and a cam that will need a 4500-5000 stall. Just tell him to count his losses and buy a more suited camshaft and GM injectors.
    5BA8
    3,256
    The cam specs are just dumb. Wonder what jackass came up with those specs.
    Mar 2022
    Indiana
    2,954
    Elgin lol
    Dec 2019
    MS
    567
    Had a guy tell me he bought a cam and thought the specs were way off and remembered this thread..
    Its a Elgin E-1255-P after looking around.
