Greetings!
For those that have helped with my previous threads. Thank you! I've got the cold start/idle issues resolved. Overall, I'm very happy with how the truck runs now! The one caveat: when at low, steady-state throttle positions (2-8%) the truck will "surge" a little. I've figured out that this is due to the AFR swinging fairly wildly (down to 12, sometimes up to 18). It only does this at this throttle setting. Idle AFR is consistent as are all other throttle positions. After tons of logging, tune changes and a swap to SD I've figured out that it is due to oscillation in my MAF. In those throttle positions the MAF output will swing up and down by 20-30% consistently. More throttle: MAF output is smooth. Less throttle: MAF output is smooth. In SD it runs perfectly at those throttle settings. No I'm not going to run SD just now- I am building a tune for it but there is a bunch of other weird drivability shit I'd have to work on.
My question: Is there a way to smooth or filter the MAF output? Ideally at one throttle setting with no other changes it should be reading the same and not swinging around, correct? I'm running the engine manufacturer's suggested intake and MAF sensor. I'm guessing it is the intake not flowing air smoothly at these throttle settings that causes this? I've also tried other new MAFS and they do the same thing. Is there a way filter these changes, turn down the sample rate or otherwise mollify how sensitive the sensor output is?
Thanks again guys!
