Originally Posted by
blindsquirrel
Well I see it idling at 25-28 kPa MAP, and I suspect that's physically impossible. Are you sure it has the MAP sensor original to the truck? Because if your LY6 is a 2009 or newer it has a different MAP sensor, both externally/fitment-wise, and also different electrically. If you have the 2009-up MAP that has linear/offset of 128.20/-0.030 but have the tune file set up with the original MAP's settings of 94.43/10.34, that would explain both the bad running complaints and the super-low kPa at idle.
If you still have the stock LH6 injectors why does that file not have stock LH6 injector data in it? It looks like some of the data was just changed at random for no reason.
