Results 1 to 6 of 6
Thread: Need a 2002 Express Van 5.7 with a 4L60E
    Oct 2008
    Mebane NC
    475
    Going to be doing a 411 conversion on a 92 Buick Roadmaster Wagon. Will be changing the intake to a Pro Flow and the trans to a 4L60E.
    Dennis
    7,821
    One in the repository with 4L80, with 12212156 OS, so 4L60 segment swap is available from either F-body or trucks, both of which used that same OS.
    Oct 2008
    Mebane NC
    475
    I'll go grab that file and make the segment swap.
    Thanks D
    7,821
    Quote Originally Posted by TZTuning View Post
    Better check that repository tune with a fine tooth comb. It’s questionable at best. I segment swapped with a s10
    It is stock. I checked the VIN in the TIS lookup and every single one of the CVNs match, there are zero changes from stock in that file. Go run it yourself and you'll stop posting that there's something not right about the repository file.
    https://tis2web.service.opel.com/tis2web/
    VIN is 1GAHG39R621203269
    7,821
    So if it wasn't right for your specific non-stock combo then it's that file's fault? Jesus.
    5BA8
    3,445
    Never said that either. Just simply saying to double check everything. My trucks all stock except exhaust. And I had to change a good bit of stuff to make it work in my application.
    How does that make it "questionable at best"?
    Better check that repository tune with a fine tooth comb. It?s questionable at best. I segment swapped with a s10
    email=[email protected]
