Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Some info on the torque-based throttle follower
    Tuning Addict
    6,808
    Don't hold your breath, Greg's still waiting for his job.
    Huh? My tool can wait. Actually kinda wondering about this fix myself I've got another customer that I talked to today that i think is doing the same thing from what he's describing with light pedal bucking only his is a really big hp build that another tuner worked on. Of course other tuners worked on Rob's too, so if this is a permanent fix, I'm all for finding out...
    ~Greg Huggins~
    Aug 2021
    844
    LOL Shame on you Greg! Holding up progress waiting on that tool! Ahh.. im just messin with you. Hopefully, there's a fix or maybe ive just not got it dialed in as much as it should be but it seems to get a little better the closer the fueling gets. I've failed the maf and been using LT ST trims to make corrections. The table has started to change shape vs when the maf was active. It seems the numbers were over inflated to make it run as smooth as it had been. We will see where this lands me. May make some progress tomorrow since i have an hour commute (one way) for work.
    Tuning Addict
    6,808
    Well I did say after doing the torque model you would have to dial it back in again due to the throttle changes....
    ~Greg Huggins~
