'05 GTO LS2 M6 Torque Management?
Hello,
I'm swapping an '05 GTO LS2 into an older car. I will not be using the GTO trans or needing TC.
Is it possible to completely eliminate the engine TM in my application? Should I stick with the stock fly by wire throttle, or convert to cable?
Thank you for an assistance!
What will you be using for a pcm?
And, yes, I do not see any issue with eliminating all of the TM.
Hi James,
Thanks for the reply. You have done AMAZING work on my Lightning and I hope that you will be willing to tune my LS2!!!
I plan to use the '05 GTO M6 PCM. Would you recommend going a different route on the PCM?
The car will be built in Birmingham and I want to bring it to you when I pick it up.
Regards,
Travis
Sorry I didn't see this earlier. I do not have "email notification" turned on here.
I would stick with that pcm, yes. Might as well stay with the ETC, too. As long as there isn't any issues to deal with, then that should be very straightforward and easy to tune, bud.
BTW, thanks for the kind words above.
Thanks for the help, James!! I was hoping you'd say that.
I'll see you soon for a tune,
Travis
