Results 1 to 3 of 3
Thread: need help idle tunning 5.3
    Sep 2023
    8
    Total newb but willing to learn I never expected it to be easy.
    99 5.3 LM7
    4.8 pistons
    truck Norris cam 212/22x .552/552 @ .050 107 LSA
    speed Enginering long tube headers
    truck intake and stock injectors
    no wideband o2 yet
    things I've changed idle air +2% ,COT off ,idle increased to 850 ,over speed and under speed X 50%
    Trying to get the idle better cant drive it yet still have alot of body work to do but i need to at least be able to move it in and out of the garage.
    Jan 2015
    Arizona
    452
    Quote Originally Posted by Johnsz28 View Post
    Total newb but willing to learn .
    Start here and follow this.
    https://forum.hptuners.com/showthrea...e-(w-pictures)
    You will be on track, and able to most of your low speed/cruise tuning, you wont, can not i mean tune WOT until you get a wideband.
    13,565
    I'd put in a 2001-2002 VE table to start with and I suggest getting larger injectors for when you do start really tuning,
    The stock injectors are fine while you finish the project but once you do full throttle tuning past 5,500-6,00rpm, it's likely to run out of injector headroom. You can run stock 8.1 injectors which at 31lb/hr or go to flex fuel injectors which are 33lb/hr. All the data is available.
