Results 1 to 12 of 12
Thread: Help Please guys
    Jan 2024
    11
    Help Please guys
    Could one of you guys please have a look over the tune i have just tried.
    It drove fine for about 2 minutes and then went into limp.
    I am trying to get this pig running properly. not to much avail.
    L77 no DOD
    VCS5SC- 224/[email protected]
    long tubes, stock heads, cold air intake. Stock 6L80E transmission.
    Jun 2020
    33
    Returning the vve table to stock and starting again would be a good start, it is a mess.
    Aug 2006
    5BA8
    3,253
    Where did your base file come from? The ETC tables have been modified. I'd bet it's setting a P0606 code.
    There are multiple Holden files in the repository. I'd pull more than one and do a comparison. Yes the VVE is a train wreck but these are the root cause of your limp mode problem.
    EFI specialist
    email=[email protected]
    Jan 2014
    Australia
    1,984
    some strange stuff in this tune file, the a/c settings are wrong as u dont want the a/c spinning and full rpm it usually cuts out bout 4000rpm then re enables couple hundred less then that, also the alternator control the holden VE should have the ecm override enabled, also your tyre size is set to over 5000cm which is half a km circumference ? does the speedo actually work ?
    Aug 2006
    5BA8
    3,253
    5000cm=50m still way too high.
    Just went and checked it and yeah it's 53 meters. Way too high. As opposed to the compare file I'm using which is 2.1 meters.
    EFI specialist
    Jan 2014
    Australia
    1,984
    aah yea damn zeros got me, yep stock should be around the 2m depending if they came out with the 19'' or 20'' wheels, the vss tyre revs are a bit odd too they are usually around where the trans ones are or little higher
    Jan 2014
    Australia
    1,984
    prob wouldnt get into any knock either that low octane table is same as high octane and 26 deg isnt always good on our fuel best i got n/a was bout the 22 max
    Jan 2024
    11
    Thanks guys, Am completely green at this, so any help is appreciated!
    Jan 2024
    11
    Thanks for the input guys,
    I have made some adjustments as to what you guys have suggested.
    edcmat-l1- Yes it was throwing that code.
    If you could look at the new tune and provide some instruction as to if there is anything that is noticed to be out of the ordinary....
    Its a small blower cam in a N/A motor, would this be why i am getting a little flatspot when the throttle is being depressed?
    or is there another gremlin floating around?
    Nov 2017
    1,466
    Anytime you change a tune, you really need to add a log with it.
    Aug 2006
    5BA8
    3,253
    This.
    EFI specialist
    Jan 2024
    11
    Adjusted....
    Thanks for your patience guys.
    I have made some adjustments to the tune, and got to take it for a short run.
    feels a bit sluggish, might be able to add some more spark and maybe change the EOIT a little, but am not completely sure if I will be doing things right.
    But, didn't stall, and didn't have a flat spot. So there's a positive....I think.
