Results 1 to 6 of 6
Thread: Tuning Help 2007 Yukon XL 6.2L swapped to 6.0L
    Oct 2010
    6
    Good Evening,
    I recently motor swapped a 6.2L out of my 2007 Yukon XL that had DOD with a 6L80E Transmission AWD. It was replaced with a 6.0l, with VVTI deleted, chevy hot cam added, factory muffler replaced with a magnaflow, and exhaust straight pipe from Catalytic Converter out to muffler then exit.
    I have an older MPVI Tuner and have everything set up. I am looking for help tuning the truck.
    It will not start easily, it stumbles extremely bad. I can get it to start by turning it over multiple times and it finally catches, or I can bleed the fuel rail manually while someone is cranking it and it will start. After that it runs fairly well, but the transmission shifts hard going into higher gears and then shifting down.
    Could someone help get me started with this? It would be greatly appreciated.
    Posted the Info Log below.
    Oct 2010
    6
    1/21/2024 4:20:21 PM
    VCM Suite Product: VCM Editor 5.0.4
    Operating System: Windows 11 (build 22631)
    Microsoft .NET: 4.0.30319.42000, 4.7.1 or later
    CPU: AMD Ryzen 9 6900HX with Radeon Graphics
    Available Memory: 7,882 MB
    Device ID: 1112617493
    Available License Slots: 406/409
    [Specific Vehicle]
    2004 Pontiac GTO (8 cyl), 0KA026333240, [GTOscout], (GM: 2)
    [Vehicle Type]
    2001 Chevrolet S-10 (6 cyl), (GM: 4)
    Hardware: 0121
    Firmware: 0121
    PartNumber: 0000006221
    BuildDate: 7/27/2009 12:00:00 AM
    InterfaceOnTime: 00:00:13.7150000
    ROM: 00 3F 00 82 00 01 00 00 FF
    Config: CC 00 00 00 00 40
    System Info: F7 00 00 00
    Comm Errors: 00 00 00 00 00
    SPI Info: 00 00 00 00 00 00 00 00
    VehicleConnectedTime: 00:00:13.7150000
    DetectedProtocols: CAN
    Protocol Info: ISO 15765-2, J1962: CAN, 500 kb/s
    ECM: 7E8, CAN - E38, GM Gen4 V8
    VIN: 1GKFK66827J278475 - 2007 GMC Yukon XL 1500 Denali, 6.2 L, V8
    Serial: 86YPLAK16291RP5P
    Programmed State: Fully Programmed
    OS: 12614088
    Calibration IDs: 12614088, 12623214, 12614214, 12614295, 12616100, 12614105, 12605899, 12605916
    Calibration VNs: 00000F82, 00000F95, 0000D7D5, 000095A9, 00004F15, 0000FE38, 0000C846, 0000B680
    Basic PIDs: 43
    Trouble Codes:
    P0010 - Intake (A) Camshaft Position Actuator Circuit / Open (Bank 1) (Pending, Current)
    Controller Type ID By OS: 5010
    None: 7EA, CAN - T43, GM A6
    Serial: DV0651Q033227806
    OS: 24239353
    Calibration IDs: 24239353, 24242128, 24242126, 24240661
    Calibration VNs: 00009236, 00003766, 000082EB, 000074EF
    Basic PIDs: 7
    Controller Type ID By OS: 60
    Tuning Addict
    Jan 2015
    6,813
    You need to post the log and tune file. Log of cranking and it running and the current tune it's running on.
    If "bleeding" the rail makes it fire right up then you might want to put a pressure gauge on it and see if the pump and regulator are bad. It should build and hold pressure. The amount of held pressure will vary depending on the regulator, but pressure should immediately build to 58ish psi and hold around that for a little while after key off. Almost sounds like your regulator is bad.
    ~Greg Huggins~
    Aug 2006
    5BA8
    3,253
    Yeah no telling what it is without a data log. Could be multiple sensors unplugged or not reading correctly. Unplugged ECT would cause it to be super rich on start-up.
    EFI specialist
    email=[email protected]
    Oct 2010
    6
    Current tune is what ever the factory tune was for that year model with a 6.2 and DOD. Is there a way to obtain that tune using HPT to load it here?
    I will check the fuel pressure and regulator this week and report back, I do not think there is an issue as the engine installer told me the pressure to the rails is correct, that it needs to be tuned to start easily. However I understand that it is hear say and I will have an accurate reading myself.
    Oct 2010
    6
    I will check on everything, get a data log from key on to initial start up, and report back. I appreciate the advice on where to start.
