Results 1 to 6 of 6
Thread: 10R80 with 10RStager Transbrake
    Apr 2006
    41
    I've got a 10RStager on my 2018 F150. Transbrake is operating correctly. It holds good and bump works great. Issue is when I release transbrake, the 1-2 shift is severely delayed. If I light throttle it after release, it takes about 5 seconds to shift. If I try to WOT it, it will hit limiter. I've turned off the codes recommended by True Motorsports. They are telling me to use Lund or Juggernot. I've logged every PID in the Transmission side and really don't see anything causing it. It simply delays the commend to shift to second.
    Advanced Tuner Josue Galban's Avatar
    Jan 2023
    Venezuela
    205
    Quote Originally Posted by ssmotors View Post
    Swipe the file to take a look at it, are you sure you didn't miss any time limiters instead? Remember to set the delay to 0 because if you don't you will have that delay
    tuning and high performance
    my contacts is
    email [email protected]
    whatsapp +58 4149648393
    instagram quickxstep
    Apr 2023
    3
    Ever get this sorted?
    Apr 2006
    41
    I ended up switching to a whipple file that had more transmission stuff That strategy file wouldn?t even load the Transbrake custom OS.
    Apr 2023
    3
    So when you swapped to the other file did you have to disable anything else?
    Oct 2016
    Poland
    1,763
    Quote Originally Posted by Relaximdevin View Post
    Yes we did.
    Of course.
