Results 1 to 3 of 3
Thread: DBW pedal and TB vs TAC (LS2 into LS1 Holden Adventra)
    Jan 2024
    1
    Hi,
    I've got a 2005 VZ LS1 Holden Adventra that is DBW. I have put an LS2 in. I got it running using an Xlink on the throttle body.
    I now have a throttle pedal failure (common for the blue sticker version)
    I have purchased a DBW throttle pedal that suits a VZ LS2 (white sticker).
    Although I have the Xlink and an Ultimate Conversion Wiring converter for the different pedal, I was wondering what the TAC actually uses for comparing the pedal and the throttlebody? Given i now have a matching pedal for the throttlebody, can i just change some pinouts/plugs to suit and the TAC will just compare pedal to TB? Or does it have preprogrammed figures that it needs to see? Or am I completely off track/missed things with my thinking? The more I can avoid electronic converter boxes, the better lol less to go wrong.
    Thanks.
    Sep 2020
    6
    So it seems I found my old account. What I forgot to say was can the TAC be edited? IF it has values in it that are referenced?
    Jan 2014
    SoCal
    1,565
    Can you? Yes. Should you? NO. At best you will likely get a REP. At worst you could have glitchy run away throttle. Lots of those pedal commanders that modify the signal from the APP to the ECM/PCM. The only time I have ever modified TAC settings is some 2000's trucks and vans that had a throttle progression issue and GM put out software to fix it. I use SPS/TechLine Connect to fix that. Otherwise I have a hands off approach to any of the APP to throttle values. Others may have better results than I do.
