Originally Posted by
VanDamn
So a 2006 Suburban was brought to my shop after another shop swapped the engine with a used engine that doesn't have AFM. The original engine had AFM. The engine had no power & no inj pulse on cylinders 1,4,6,7. I tricked the PCM by tying in 3157 light bulbs to make it think it still had the AFM solenoids and gained injector pulse on all cylinders and the engine now has power but while idling it misses on every cylinder. It lopes and I can feel it missing. Also under misfire data on my scan tool it shows every cylinder misfiring. If I raise the RPM it clears up or while driving the miss clears up but as soon as it returns to idle the miss comes back. I have also replace the PCM and used a tuner to delete the AFM with no change, it still misfires on every cylinder at idle. Anyone dealt with this before, where should i start? TIA!
