Results 1 to 5 of 5
Thread: Need Base Tune for LS1!!!
    Jan 2024
    Talking Need Base Tune for LS1!!!
    Hello!! I've got a 2000 Trans Am that I need a base tune on for my break in period. It's got a short ram 102mm intake and throttle body, 100mm MAF, 50lb injectors, LS6 243 heads, BTR Stage 2 NA cam and Speed Engineering 1 7/8th headers. Whatever other info you guys need I'll get it for you. Car currently starts but will not run for more than 5 seconds and then it stalls out.
    13,565
    A start would actually be posting your tune file, kinda need that to even begin to help you.
    Also kinda need to know who's 50lb/hr injectors they are and if you even plugged in any data for them.
    Jan 2024
    They are Bosch injectors part # 0280158117, I have not plugged in any data for them.
    13,565
    Ah, well good luck finding the correct GM data for those. Maybe someone has it but not always the best chance when they are ford injectors.
    Mar 2022
    Indiana
    2,944
    I used the sheet in the link to convert the data from a 2008 GT500 then updated the tune for you.
    https://forum.hptuners.com/showthrea...l=1#post745107
    Injection timing based on cam specs, assuming from your description you mean 32738132R0 (227/238 .620"/.605" 113.5+2.5). If not let me know. Changes made at Fuel>General and Fuel>Transient.
    Need any more help just ask.
