Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Help ls swap iii ls iii gen
    Jan 2014
    25
    I have an ls swap with 12613412 injectors, high flow air filter, GEN IV intake manifold. but the moment I half touch the accelerator the wideband goes over 20, could someone help me check the tune?
    13,565
    Did you get the injector data for those injectors?
    I'd put the MAF and VE tables back to a stock 6.0 values and start over too.
    7,649
    You've changed injectors but only changed the flow rate, the other injector tables still have the L59/12580426 data.
    Does it still have the 2002 L59 fuel rail/referenced regulator/fuel system, at 51 PSI? Or does it have the Gen 4 rails and an in-tank regulator (58 PSI)?
    Jan 2014
    SoCal
    1,565
    You say it is a Gen 4 so I have to assume it is a returnless. If so you injector data is wrong. Even if you used a return style your data is wrong. https://forum.hptuners.com/showthrea...ata-Repository Use Blindsquirrels data on this post. https://forum.hptuners.com/showthrea...l=1#post748451
    You HAVE to start with good injector data. It is top of the list in importance.
    Jan 2014
    25
    I am using 12613412 injectors, 450lph fuel pump and mechanical fuel regulator, intake manifold, iv, fuel rail iv gen, throttle iv.. what should I do?
    7,649
    Is the regulator referenced (little vacuum hose to it from somewhere on the intake manifold)? What is the fuel pressure?
    The injector data will depend on whether the fuel pressure changes with manifold pressure, or if it's constant regardless of what the engine does.
    13,565
    I'd still put in a stock 6.0 MAF and VE table, for sure the VE is not stock.
    Is the exhaust 100% complete? You can't run open headers with a wideband,
    Jan 2014
    25
    The exhaust is 100% complete, there is no stft or ltft installed, I even tried to increase the fuel by 10% or more and the vehicle when touching the accelerator remains between 20 and 22 afr, and has a hard time reaching 2,000 rpm
    13,565
    What MAP sensor did you use? The one for the 2002 Suburban like the tune file is from or from the NNBS intake you swapped over?
    What throttle body did you use too? The tune is setup for DBW, so which did you use for that.
    Nov 2017
    1,466
    Quote Originally Posted by harry.bravo View Post
    What do you mean by “no stft or ltft installed”.
    How did you try to increase fuel? Have you confirmed fuel pressure under all running conditions.
    Jan 2014
    25
    The fuel pressure is at 60 psi (constant) according to the fuel regulator that is installed in the car, but as I said before, even if you half touch the accelerator, the aft goes to 20 - 22, try to increase the maf between 25 at 30% even just 10% and the car gets worse and the AFR numbers never go down
    Jan 2014
    25
    3 Gen map sensor and 92mm throttle body
    Nov 2017
    1,466
    Have you put a diagnostic fuel pressure gauge to it?
    Jan 2014
    25
    Yes and the pressure gauge indicates a constant 60 psi
    Jan 2014
    25
    Jan 2014
    25
    Load the corresponding data into the fuel tables, the fuel regulator is set to maintain 60 psi, but still doing that. At the moment of half touching the accelerator the wideband marks on its afr 20, 22
    Nov 2017
    1,466
    Assuming that gauge is correct and there are some on here that would say a gauge like that can’t be trusted, how are you checking pressure under load? I don’t know that it’s your problem but not sure that you know either.
    Jan 2014
    25
    I apply the car in D so that it has a load, but even when applying the brake and a little accelerator well before 2,000 rpm, the pressure still remains at 60psi and the wideband continues to read between 20 and 22 afr
    13,565
    You didn't answer my question fully.
    Okay it's a 92mm throttle body but you never said what type of throttle body. Is it drive by cable or drive by wire?
    I also think for the hell of it you should turn the fuel trims back on, if those are showing stupid positive then you can trust your wideband sensor. If they aren't going crazy, then your wideband is bad.
    Jan 2014
    25
    Throttle by Cable
