Please consider me a novice, so be nice.
I am attempting to use an AEM feed into the scanner to determine AFR / Lambda ratio errors. Going to then adjust the VE tables to as close to 1.0 Lambda as possible. I have studied and understand the basic need for power enrichment tables but am having trouble understanding how this should be used in relation with the VE table. If I use the AEM and obtain 1.0 Lambda for all cells, doesn't this negate the impact of the PE table? If so, how do you tune the VE to ensure an actual ~0.85 ratio for areas of the table that need additional chamber cooling? Should or can PE be turned off like MAF to dial in VE (I really don't like this idea). May be overthinking this, but very confused as to the interaction of PE and VE on needed AFR.
If I am not making sense, please let me know. Definitely a noob here.
Andy
