Originally Posted by
edcmat-l1
First off, you need at least 1 bend after the O2 sensors. Needs to be at least 45 degrees, 90 degrees would be better.
Second, you need to know what "normal" looks like. Your AFR in closed loop is going to bounce around continuously. It's not going to stay stable. It's supposed to toggle lean-rich-lean-rich. Slightly below stoich to slightly above. That's normal. +25% LTFT is too far off but you can't make adjustments and expect them to be correct with just straight pipes.
