Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Turbo 5.3 tahoe fuel issues
  1. #21
    Mar 2022
    Indiana
    3,009
    Yeah something is definitely wrong. I like gametech's suggestion.
  2. #22
    Jul 2021
    17
    I dont have any evap on my tahoe, i did try the stock ve table the -15% at idle an results were needed pedal to start, no idle unless u held it the pedal open slightly. Could my map offset cause these problems? Im 3 bar os koeo i get 105kpa bounce 0 then 105 then 0 engine running it reads 65-70 sometimes lower. My baro says 15.1 im 400m above sea level
  3. #23
    Nov 2017
    1,544
    Have you confirmed the map sensor linear and offset with the part number of the sensor?
  4. #24
    Aug 2006
    5BA8
    3,469
    Quote Originally Posted by json View Post
    If you're at 400m your Baro should be around 95 Kpa. That being said, it'll throw it off some, but not nearly as drastically as it is now. It looks like it's setup for the red label GM sensor. If that's not what you have, that's what you need to get. Not a knock off Napa, etc., buy a GM part. PN 12592525
    It's obvious it won't run with your VE setup they way I described and you did. My point was, set it up that way and start raising your injector flow rate until the trims come into line.
    EFI specialist
    email=[email protected]
  5. #25
    Jul 2021
    17
    Im working on IFR now, that was just to get a current log an tune for you guys, the map sensor i have is a ac delco PN 213-4434
  6. #26
    Aug 2006
    5BA8
    3,469
    How did you end up with that PN? That does not sound right. Did a quick search and that doesn't even look like a 3 bar sensor. You need to get a GM red label and a connector pigtail.
    EFI specialist
  7. #27
    Jul 2021
    17
    How do i go about mounting the gm red label to my truck intake?
  8. #28
    Aug 2006
    5BA8
    3,469
    I can't tell you off the top of my head. I build way more cars than trucks. I do know you'll need to drill the hole slightly.
    EFI specialist
  9. #29
    Jul 2021
    17
    I ordered a adapter thanks when everything is in ill post a update.
  10. #30
    Jul 2021
    17
    back with new sensor
    new map sensor https://www.efisource.com/wp/shop/ls...ar-map-sensor/, new head gaskets need help scaling tune5 psi.hpltahoe sloppy 06 new new.hpt working on wiring my wideband so that afr can be logged.
  11. #31
    Jul 2021
    17
    Also now have 1:1 fpr with return-less rail at 43.4
