Thank you for modifying that for me.
The math at idle warmed up gives me a SOIT of 385 degrees which is perfect as the EVC event is 393.5 degrees.
I'm going to post the before and after and I am wondering if you would'nt mind explaining to me why you made the changes you did?
Attachment 141544 My Tune
Attachment 141543 Tune with your changes
I noticed on the injection boundary table you more or less reversed the numbers I started out with and increased them a fair bit from 4000 rpm and up.
On the E13337 Normal ECT you decreased the numbers from 110 to 85.
On the E13338 Normal RPM the higher numbers are cut almost in half and the numbers were also raised a bit to reflect the power band of the Cam as compared to stock.
Now lastly Im very curious and noticed that you turned Make Up mode off. It was set to Multiple. Can I ask why you did this?
I am in no way doubting what you changed as I am sure it will work better than what I have and I really really appreciate it, but I'm the kind of person that would like to understand why the things that were changed, were changed.
I will flash the changes to the car tomorrow and report back on how it runs
