I have a 2010 sierra 1500. Factory 4.8 4l60e. Installed a l96 6.0 from 2014 2500 and a 4l80e out of a 2005. I used the pcm of nc 4l60 to 4l80 adapter harness. The motor has a texas speed vvt stage 1 cam kit 220/230 .600/.600. Transmission has transgo hd2 shift kit and a 9.5 inch 3200 rpm torque converter. 14 bolt rear with 4.11 gears. The truck seems to run and shift good. I'd like to get opinions on the tune to see if it looks safe and to see if im leaving any power on the table. I would especially like to make sure the trans and converter looks safe. I raised the virtual torque tables by 20% at wide open and interpolated vertical bounds then added 15% to the entire tables. I tried to get rid of the pwm on the converter. The trans pressures and times are stock in the tune. I cut the trans torque management in half. I'd like to know if I'm on the right track or not and I might have missed something completely obvious. Thanks
