2013 LS7 with tune. Car ran fine, then about 20 miles after re-fuel, engine started sputtering and died, restarted it while coasting and revved it for a second, then it died. Had to pull off the side of the road, it would restart but immediately die. Had to trailer it home, and could not work on it due to job, but I have some time now.
Thought it might be a bad fuel pump, but checked rail pressure and read about 50 psi, which I think is good. Connected VCM Scanner and got the attached data. The data is for three starts (three tries), and is just for a few seconds. I'm not sure if the data points to an issue, but thought someone more knowledgeable that me could quickly tell if there was a problem.
There are no DTCs, except for P0420 - Catalyst System Efficiency Below Threshold (Bank 1) (Permanent), and P0430 - Catalyst System Efficiency Below Threshold (Bank 2) (Permanent). Not sure why these are there but I think that I might be running rich from the shop tune.
I'm going to swap out the fuel, in case I got bad gas, but again, car ran fine for at least 20 miles after the refuel. When the problem first came on, it was quick, so I don't think it's the fuel. The problem (starts then dies) is so consistent that again I don't think it is the fuel. I'll advise after the fuel swap. Any help/suggestions with the log file would be appreciated.
Dave.
