Page 5 of 8 FirstFirst 12345678 LastLast
Results 81 to 100 of 155
Thread: New Fuel Pump VE Try 2
  1. #81
    Mar 2022
    Indiana
    3,002
    I wouldn't give up on it yet. If you're not noting anything mechanically then keep running it and see if it clears up. Have you thought about ditching that Mobil 1 crap for a real oil? Try QS Full Synthetic and do a UOA on that.
    Are you good sticking with a MAF tune? Want to work on spark?
  2. #82
    Apr 2022
    217
    Oil pressure is fine, maybe dropped a tiny bit since break in. That’s why I keep questioning if it’s a mechanical issue causing the pops hear and there or it’s just heavy load low rpm and these injectors aren’t meant for that. I’m still building my old 6.0 back up in case this goes. But moving forward the MAF 4 file is what I’m running I do notice pops but that’s in a scenario say I’m cruising light throttle then like ease into the throttle then stay at a steady rate that’s when it will pop. Mainly in the High Map Areas
  3. #83
    Mar 2022
    Indiana
    3,002
    What I'd do is check the UOA with a better oil and get some Gen IV injectors.
  4. #84
    Apr 2022
    217
    Going to send another analysis out then order injectors depending on that. It?s been running ok but I just feel like it?s getting noisier. CEL blinking at stops again not sure if misfire code was re enabled in maf 4. it won?t pull a code and goes away once I leave the stop light etc.
  5. #85
    Mar 2022
    Indiana
    3,002
    Go to EngineDiag>Misfire>Cylinder Mode. Set the idle tables to 32,767.
  6. #86
    Apr 2022
    217
    Got the injectors number 12613412
  7. #87
    Apr 2022
    217
    used blindsquirells referenced data copied it over to my tune now. Fired right up lets see how these go
    50LB INJECTOR RUN 1.hpl
  8. #88
    Mar 2022
    Indiana
    3,002
    Alright. Got the tune for that log?
  9. #89
  10. #90
    Mar 2022
    Indiana
    3,002
    Here's the next revision.
  11. #91
    Apr 2022
    217
    Awesome, did that log show any difference or Have to drive longer?
  12. #92
    Mar 2022
    Indiana
    3,002
    Yes there were differences. It wasn't in SD, so we'll have to wait until then, but I think there is where we'll see the biggest difference.
    That log was excellent btw.
  13. #93
    Apr 2022
    217
    heres a log. Knock was from converter locking in 4th at low MPH
    injector 50 maf 1.hpl
  14. #94
    Mar 2022
    Indiana
    3,002
    Looking good. One more to confirm.
  15. #95
    Apr 2022
    217
    no popping with these injectors lol wonder if i should try to get my money back for the others
    INJECTOR 50 RUN 3.hpl
  16. #96
    Apr 2022
    10
    Quote Originally Posted by Lxjoshxl View Post
    wtf! gonna cause me to get rid of mine! lol
  17. #97
    Apr 2022
    217
    Quote Originally Posted by Jakeallred View Post
    Which ones did you have? What problems are you having
  18. #98
    Apr 2022
    10
    the 44lbers deatschwerks with high ve table
  19. #99
    Apr 2022
    217
    We’ll I will see more in SD on how these are. Did you get any popping sounds at lower rpm’s with yours? These injectors for $120 can’t beat it. Glenn’s auto
  20. #100
    Mar 2022
    Indiana
    3,002
    Yep we'll see. Moving on to SD. I'm excited about this part, too.
