Results 1 to 5 of 5
Thread: leaning about tunning on a c6 z06
    Dec 2023
    3
    tuning newbie on a tuned c6 z06
    back story: I had my 07 c6 z06 tuned by a reputable tuner in san diego CA with a chinese 102 tb. The issue with it was that it made the car jump from time to time, so my tuner tried to do some adjustments in it to make it work a bit better. Fast forward a year later I just recently installed a nw102 ported tb and trashed the chinese tb. I am still learning about tunning and started messing with the spark and idle by the engine button on VCM editor. I also did some logs after.
    What i've done so far on changing the tune that my tuner did was the Idle adaptive spark control > underspeed > overspeed
    set idle maximum set point > 975
    idle > proportional > 50 rpm
    idle > integral > enable rpm error > 10 rpm
    now the problem is if i change my spark at idle how would i go to change it so that i dont buck so much from idle to gear but still maintaining the chop. Any help to make this newbie understand a bit more about tunning is very very appreciated.
    here is my logs of me idling and partial slight throttle to the corner gas station.
    Edit: I also forgot to mention on my spark > advance > idle spark advance> base chart. @1000rpm i have a value of 14 from .08 to .48. Ii would like to know why is this value such a huge spike and could this also be the reason of my tuner trying to play with the chinese tb?
    Aug 2006
    5BA8
    3,254
    What promod camshaft you running to require a 950 rpm idle? I can typically idle stage 3 and 4 cams at 750. What are the complete specs on the build?
    Oh yeah, and tuning is spelled with 1 N.
    EFI specialist
    email=[email protected]
    Dec 2023
    3
    BTR4 for ls7. Im not sure why it was set to 1100 max to min 900. Thanks for the grammar correction. LOL
    Aug 2006
    5BA8
    3,254
    Quote Originally Posted by kuan098760 View Post
    Sorry. It's one of my pet peeves LOL
    You should be able to idle that cam at 800 tops. Although if you're after smoother 900 might feel better to you.
    EFI specialist
    Dec 2023
    3
    thanks a lot. i got it to chop but its not chopping fast enough.LOL
