Results 1 to 12 of 12
Thread: little help with 5.3 tune after camchange
    Dec 2023
    5
    log to send.hpl dont know if i attached the log right or not but was wondering if someone would look at it and tell me what they think .truck cranks and runs but has no throttle responce. its a 2012 silverado 5.3 , I just done a dod delete ,vvt delete. put a btr truck cam in it stage 3 . have deleted dod in tune and vvt in tune . its throwing dtc codes p0010,p3401,p3425,p3441,p3449log to send.hpl 0x543: U2100 - CAN Bus OFF (SES, Pending)
    0x7E8: P0010 - Intake (A) Camshaft Position Actuator Circuit / Open (Bank 1) (Pending, Current, Old, Permanent)
    0x7E8: P0446 - Evaporative Emission System Vent Control Circuit (Pending, Current, Old)
    0x7E8: P3401 - Cylinder 1 Deactivation/Intake Valve Control Circuit/Open (Pending, Current, Old, Permanent)
    0x7E8: P3425 - Cylinder 4 Deactivation/Intake Valve Control Circuit/Open (Pending, Current, Old, Permanent)
    0x7E8: P3441 - Cylinder 6 Deactivation/Intake Valve Control Circuit/Open (Pending, Current, Old, Permanent)
    0x7E8: P3449 - Cylinder 7 Deactivation/Intake Valve Control Circuit/Open (Pending, Current, Old)
    Tuner Guy With A Chevy's Avatar
    Aug 2023
    Corpus Christi, TX
    184
    You need to post the tune for quality help
    Dec 2023
    5
    I will when I get back home I thought I had but obviously not
    Tuning Addict
    6,815
    You did install the correct front engine cover and have the right harness going to the cam sensor and right cam sensor in general?
    ~Greg Huggins~
    405
    2,326
    Those are permanent codes. Going to guess you didn’t disable them before you tried to start it. They will never go away now.
    Dec 2023
    5
    Yes I installed the new cover
    Dec 2023
    5
    New timing gear and everything
    Mar 2009
    Andover, MN
    458
    Without pulling code info from SI, I might look into the U2100.
    Tuning Addict
    6,815
    99% of those need to be set to no error. No longer applicable since VVT and DOD was removed
    ~Greg Huggins~
    Mar 2009
    Andover, MN
    458
    none of those codes would make a no throttle response besides the CAN fault. Maybe REP mode i suppose. My guess is the throttle isnt talking to the pedal. Just a pure guess.
    Dec 2023
    5
    Quote Originally Posted by ns158sl View Post
    igot the codes cleared wil you check this new log and see if you see anything 2nd log.hpl
    Indiana
    329
    Set those codes to "no reported error" and if youve actually disabled DOD, VVT, AFM then do a write entire without high speed.
    Post tune.
    "I don't care how it runs as long as it chop chops at idle"
