Page 3 of 3 FirstFirst 123
Results 41 to 45 of 45
Thread: Flex Fuel Sensor Not Accurate
  1. #41
    Aug 2006
    5BA8
    3,330
    I think you'd increase the 100% cell by however much it takes to put the 60% cell at the right spot, when the table is interpolated. If I'm understanding what's been said earlier.
    That's correct. If your 93 is 10% you'd want to interpolate from the 12% cell to 100%. So you leave the 10% and lower part of the table alone.
    EFI specialist
    email=[email protected]
  2. #42
    Feb 2018
    830
    Got it, thanks again
  3. #43
    Feb 2018
    830
    Yes. Once your base calibration is done, this is where you should bring your trims back in line on E if they're off. And you use your alcohol PE to adjust your WOT A/F on E. The idea is you don't want to touch your base calibration once it's done.
    So, I was re-visiting this thread and when you say adjusting your alcohol PE table to adjust afr, do you mean "raping" the alcohol PE table slightly? Since the maf curve should no longer be touched?
  4. #44
    Aug 2006
    5BA8
    3,330
    Quote Originally Posted by sgod1100 View Post
    Yes. Once all your petrol tuning is done and spot on, you don't want to touch it. Any adjustments needed to be made for E tuning need to be made to alcohol tables only. That means skewing the PE if needed. I always start with copying the petrol PE to the alcohol. If it needs tweaking, so be it. In OE FF calibrations the alcohol PE is different from the petrol PE. In a perfect world they'd be the same but that never happens.
    EFI specialist
  5. #45
    Feb 2018
    830
    Got it. Thanks again for all the info you have given me/us on this thread!
