hey guys, so after researching and going through my tune file and poking around, i'm becoming more familiar with the tuning process. that being said there is still a lot i don't know.
after reading a lot on here and other forums and youtube - i'm seeing things being turned off during the process. after nosing around with what i'm learning in the editor, i've noticed things still turned off that the majority of info i've found says should be re-enabled. things like cat over temp and long term fuel trims. finding these things off makes me have some concerns...like do i have an issue going on the turner just bandaided with turning these off and turning codes off like map sensor codes being set to second error, o2 sensors being set to no error reported for heater control circuits etc, or is this standard? (there are more than jus these two dtcs being changed)
and would it be bad news to turn LTFT back on?
i also noticed that maf is the primary for of calculation (set to 400 rpm). is this the reason why the ltft were left off?
attaching my current tune for reference
5.3 btr state 2 nsr truck cam dur @ 0.050 212 218 - lift .481 int exh - lsa 111 .560 btr spring stock everything else. full emissions on this daily.
Thanks!
