I am having a problem with the trans, it does not want to make any type of change, it is well configured, it is a 4l80 in a 4gen ls swap, my odometer reads 255kmh and the trans since you start starting it is set in 4th gear, what should I do? adjust the shift points? I don't understand what is happening and it is extremely urgent to fix this problem, I suspect it is because it reads 255kmh
