Results 1 to 10 of 10
Thread: 06 tbss
    Dec 2016
    21
    06 tbss
    hey anyone every ran across a e40 ecm missing the 1250159 code modification for the 2 bar. its not in the file nor is it loaded into it. the OS currently in the ecm is 12619014 any help would be great
    7,649
    How about you post this file you have the question about so someone else can look at it and see if they see the same thing you do?
    7,649
    12606494 is the 'normal' OS, 12619014 is an optional 'Select this operating system only to prevent C0244 at low ambient temperature' oddball.
    Dec 2016
    21
    Here is the file that came in the truck2006 tbss 4121.hpt
    i get its a odd OS only one other truck in my files have it
    Dec 2016
    21
    So I?m guessing the short story is that the patch isnt supported in this OS I?ll have to have flash it over.
    7,649
    Yep, SPS and Tech2/MDI/other J2534.
    E40s are expensive, on cheap E38s it's less money to just buy a used one already VIN-programmed.
    Dec 2016
    21
    Thanks for the info. Just wanted someone else to confirm before I move on
    Nov 2006
    2,742
    Sounds like you already got it figured out.. but yes two OS's in the 06. One doesn't have a 2 bar OS available.
    We can SPS the ECM if you need.
    Tuner at PCMofnc.com
    Dec 2016
    21
    quick update:
    thanks for all the help. I swapped the the OS all is good now. hopefully this helps others as well
