Since the V6 section doesn't have an E67 pcm section and there's really no support or experience in there anyways, I thought i'd pose my question here.
I'm tuning an 07 G6 GTP which is using a form of the Cadillac 3.6 L VVT motor.
I don't understand the spark retard settings for this vehicle.
From what I can see, RPM spark cutoff is set at 6600 rpm but stock, the car shifts over 6800 rpm.
Also, another thing which I don't really understand is the maximum KR table vs rpm vs map is brutal.
Max KR from 3500 rpm to 5000 rpm is 3 and 2 for 5500 rpm, then it goes to 1 for 6000 rpm to the end of the table at WOT.
I have a 2-3 degrees of KR right now which could really be 10 degrees for all I know at certain rpms.
Now my question is... Should I make it more aggressive or is it set there because of the VVT or is it because GM thinks the motor is indestructable and it'll be okay...
What are your opinions?
I'd upload a bin, but it's 3mb.
