Right off the bat I'm the driver of this car, while I did have some experiencing with tuning my boosted VQ prior via Ecutek, I have not even remotely tried diving into this car. So the problem I have here is I've moved to a '14 C7 LT1 and put a BTR V225 in it. I gave the tuner the VVT tables from BTR and they said they noticed no difference in power using the tables provided by BTR vs setting it to 0 throughout all gears. That's six and a half dozen to me, however now the car has a light surge if you're sensitive to it at partial/light throttle when cruising under 2300 RPM. I found someone else with this issue on a different forum whose tuner said it was due to the VVT, after trying to fix it three times, they went to a lockout instead of a limiter. I'm running out of money here trying to iron out the remaining issues on this car, does anyone else have any experience with similar issues on this setup and either have a recommendation on a tuner in SEPA or any information I can discuss with the tuner to remedy this situation?
