Page 7 of 7 FirstFirst ... 34567
Results 121 to 138 of 138
Thread: 5.3 Gt45 newb
  1. #121
    Oh that looks like a badass intercooler! But unfortunately WAAAY out my budget atm.
    I think I paid 1600$ for the truck lol
  2. #122
    Mar 2022
    Indiana
    2,986
    Can you post a pic of the top of your intake manifold? I'm thinking IAT relocation.
  3. #123
    Having issues uploading pictures for some reason, idk why. I?ll try again with the laptop later. Intake manifold is just the stock truck intake. Where in the intake could the IAT be relocated? The EVAP purge valve is still installed(not used) wondering if I could put it there somehow?
  4. #124
    i appreciate the chop. sounds cool. temps are lower last few days. will make a new log on the way home when it warms a bit.fsf.hpl
  5. #125
    overcast ofc, not very warm weather . car runs good still tho. idle afrs look good.
  6. #126
    Mar 2022
    Indiana
    2,986
    Looks pretty decent. Can't quite tell tho since you didn't get into boost. It's always when the IAT's come up that problems surface.
    Here's IAT relocated to the EVAP port like you were talking about:
    https://www.youtube.com/watch?v=oGitHOIPEvU
    Having it in the EVAP will be an improvement since it's behind the throttle body. I think a better spot would be further down so that charge cooling due to water/meth evaporation can be tracked better. Something like right here:
    Either way you'd have to figure out how to keep the sensor in without the boost blowing it out. Tight fit and RTV should work in the EVAP spot, but in one of those core plugs it might take JBWeld.
    If you're onboard with IAT relocation do so then I'll make adjustments as necessary. No changes made right now. I can work on idle a bit (log STIT next one), but the rest is a fight due to OL and changing conditions. Some OL people actually run a cold weather and hot weather tune. Theoretically that shouldn't be needed if the IAT was reading the temp of air going directly into the cylinders. Same fight we're having.
  7. #127
    OK IAT is now in EVAP port.
    what is STIT ?
  8. #128
    Mar 2022
    Indiana
    2,986
    Nice work. Looking forward to a log.
    Idle Adapt (STIT). Short Term Idle Trim.
  9. #129
    Oh gotcha do I need to add that channel/PID to log it for ya? And I?ll be taking it for another spin on Wednesday. I have a short log I made but my laptop was about to die so not sure if it?s much use. I?ll upload it tonight
  10. #130
    Mar 2022
    Indiana
    2,986
    Yeah add that channel to the log.
  11. #131
    pardon the delay
  12. #132
    Quote Originally Posted by Jabootydawiz View Post
    pardon the delay
    IAT reached 199 degrees sheesh! Sensor is out of the 2000's 1500's trucks also fyi. Black plastic, just like the one in the relocation video.
    Perhaps i can trigger WM spray sooner?
  13. #133
    Mar 2022
    Indiana
    2,986
    IAT relocation helped. Actual tracks commanded a lot more consistently. Still there's the lean spike on tip-out after WOT.
    WMI is off when when you let off the pedal and the throttle shuts. If you want cooler temps it's going to be either get an intercooler or lower the boost down. I'll repeat my recommendation of 8-10psi on this setup.
    Later tonight I'll make a few adjusments.
  14. #134
    Right on I?ll take some spring out of the wastegate. Found a leaky o-ring on the fuel damper too
  15. #135
    Mar 2022
    Indiana
    2,986
    I think that'll do a lot of good.
  16. #136
    Gents, I have been following this thread and was wondering if I can get some input and help. 02 silverado, 5.3 gen4 internals, Stage 1 btr cam (can provide cam specs), deatschwerks 95lb injectors (PN:17U-05-0095-8) with flow report, vs racing 7875 .96ar t4, walbro 450 FP, and manual swapped trans. I have a mostly set up tune from a local tuner all except for the idle after 185 degrees ect... the AFR drops down to 11.9 at idle when stopped and with very light throttle inputs. If you guys can help, please just let me know what you need me to do, im experienced with the mechanical portion but a total newb when it comes to tuning or most Hp tuners related things.
  17. #137
    Mar 2022
    Indiana
    2,986
    Start a thread about it with your tune and log posted.
  18. #138
    Arizona
    483
    Quote Originally Posted by silverustoturbo View Post
    not in here you wont.
    Start your own thread
