I have recently changed the rear gears on my Pontiac G8 from a 2.92 to a 3.23 and installed a new circle D 3200 stall converter. Other than changing the gear ratio in the speedo tab, what else needs to be changed for drivability. Do I need to change my shift points or is that automatically predetermined by mph? Will anything need to be changed for the stall change?
