Looking for some direction here....First LS swap (2012 gen 4 5.3 w/ 6L80) into a 70 C10 pickup. First time using Hp tuners as well. Been a huge learning curve!!!
I modified the stock harness using the LT1Swap.com instructions. I'm using the factory truck DBW pedal. Truck starts and engine will rev when throttle is pressed. ECM is throwing P2122 & P2127 DTC codes. If I clear the codes the TPS will read in the VCM scanner tool but only ~30% to 85%. Once I start the engine the DTC codes come in and the TPS won't read, but engine will still rev when pedal is pressed. I checked a few parameter in Vcm suite with codes cleared and key on but engine off....see below.
Any input on what to troubleshoot next would be appreciated. I double checked the wires from the PCM to the pedal are the correct ones for a factory truck pedal. I can post screenshots of other parameters if that would help. Just let me know what I need to add to help troubleshoot. Thanks!
not pressed Pedal Pressed fully
Accelerator Pedal Position 1 0.94v 4.18v
Accelerator Pedal Position 2 0.45v 2.08v
Throttle Postion (SAE) 30% 83.9%
