EFI specialist
email=[email protected]
Yep. I have it in open loop for that reason, no o2 sensors just running on the ve. cruises at 14.7 and ranges from 11.5-11.8 in boost. No meth, just 93 with a single 450 pump. I do see what youre saying about the VE looking "odd." I assume youre referring to the duty cycles at a higher kPa. That is because I only have ran it up to 7 psi, so I have not yet tuned the VE in that range.
I'm referring to the overall shape of it. There shouldn't be dips unless you're pulling fuel because of some other source of fuel being introduced.
Cruising at stoich is one thing. Idling at stoich is another. I'd bet money it doesn't idle at stoich. And even if your WB says it's stoich, doesn't mean it actually is. You hook up some narrow bands and put ti in CL and it would not be able to toggle them correctly. I can tell by looking at the injector data.
EFI specialist
TEAM OL4LYFE, amirite?
EFI specialist
