I've had my car tuned by a well-known tuner; however, I've tried contacting him about my issues and don't get any feedback. the problems I'm having is my car seems to have some idle hang as well as when I press in the clutch the rpms drop down below the desired set rpm. my IAC counts are high 160+ range which I've heard you can adjust set screw to fix problem. My other concern is whenever I drive the car and get out it smells like I just poured gasoline all over myself. from what I can tell it seems to be pulling out a lot of fuel. if someone could look over the tune and tell me if they see anything concerning, I would appreciate it. Thanks.
1999 Trans Am: rebuilt LS1 bored over .005, 231/234 cam supporting mods, 243 heads, ls6 intake stock throttle body, 42lb injectors, long tubes no cats, true duals.
