Results 1 to 11 of 11
Thread: Shift times all over the place....cant figure this out
    Sep 2021
    Lexington KY
    199
    So rundown on my truck
    2014 Silverado
    5.3/6L80
    rebuilt two years ago (engine and trans)
    all GM parts except:
    LSXceleration stage 2.1 Cam
    Speed engineering long tubes and Ypipe
    3.5 in exhaust into Flowmaster 70 series
    6.2 intake and TB
    Comp cams actuator lock out kit
    LT4 springs
    hardened stock length pushrods
    everything else new GM parts, except for crank
    Stock GM converter
    Sonnax zip line kit
    all new clutches and steels
    RECENTLY replaced valve bodies (missing checkball)
    Cant figure out this random delayed shifts. Doesnt seem to matter if its cold, hot etc. This is the tune Ive been running in vehicle the longest. Up until I had the missing checkball issue, it would very rarely flare slightly going from 5-6th. Usually run it on E85. Everything on engine side seems perfect. When trans was apart, fluid still red and no metal, etc. I feel like its tune related, because I can load an older tune, and it changes how the trans acts. Shift times are all over the place. Ive done the trans adapt reset also. Somebody help! lol
    23-10-16 12-51-59.hpl
    Sep 2021
    Lexington KY
    199
    Starting to wonder if the Torque needs adjustment or DD tables. because it ONLY happens under a light load, or little throttle. I have no idea what to adjust lol
    Aug 2023
    SoCal
    452
    Quote Originally Posted by Estep40511 View Post
    Where in that log did it feel like it was shifting too late or as you put it "all over the place"? the unit seems to be doing what it is asked to do really well, I am not well versed on the tuning side so I won't be able to help if it is a command issue like you suspect. But right now, unless I am not looking at the right place in there the unit seems to be shifting right on time when commanded and the shifts are all nice and short.
    Robert Moreau
    Technical Sales and Marketing Support Specialist
    TransGo
    2621 Merced Avenue El Monte, CA 91733 USA
    Calibration | Innovation |Performance
    https://transgo.com/our-products/
    Sep 2021
    Lexington KY
    199
    Quote Originally Posted by TransGo Robert View Post
    after I got back into town, there was a 2-3 shift that took 1.0 sec. again, under a very light load. and there was one 5-6 shift where it goes to shift, flares slightly, then shifts into gear, that one was .7sec. all other times, it shifts great. Thats what is so puzzling.
    Sep 2021
    Lexington KY
    199
    Looks like around 12:47 and 12:50 are the shifts in question. very light load when it happens.
    Aug 2023
    SoCal
    452
    Ok I see the 2-3 issue now, that's 100% a command issue, the computer for some reason simply does not ramp up PCS2 like it should during the inertia phase. I am not seeing a 5-6 issue as you describe but my time stamps don't match anything you give so that makes it a bit hard. The one thing that I see that could be misconstrued as a 5-6 flare issue is on the very last 5-6 of your recording, when you tipped on the throttle the TCC slip went up to about 160 and then the went back down just before the 2-6 after the computer ramped up teh TCC apply pressure to compensate for the added load. That's normal, not a problem, but if it bothers you it can probably be tweak in the programing to ramp it up more aggressively so that it does not do that.
    Robert Moreau
    TransGo
    Tuning Addict
    Jan 2015
    6,813
    This is just an initial based off of the log you posted. Couldn't apply the correction factor because that requires the VVE to be nearly 100% dialed in and I couldn't verify how close yours was. Some of this was a projected guess, but until your torque model is right the trans can't be tuned in correctly.
    ~Greg Huggins~
    Sep 2021
    Lexington KY
    199
    Ill give this a try today and see how it changes. I reset the trans adapts again last night and drove it. seemed okay. This morning it was okay as well. Im going to do some more research on the Torque model and try to get it dialed in better.
    Tuning Addict
    Jan 2015
    6,813
    If all you're doing is resetting the adapts you might want to do a quick learn. Just make sure to pull a video up with someone using a scan tool with prompts as those are missing from hpt's procedure and follow along with the video. That will make a world of difference on it's own. I know you torque model is wrong just based off of your idle timing and off idle numbers for take off and what not.
    ~Greg Huggins~
    Sep 2021
    Lexington KY
    199
    Im using my MDI2 and GDS to reset adapts. I tried the tune you had on here. seems to really help it. Im getting ready to take it on vacation and then I will dive into this torque model tuning when I get back. Can you suggest videos or threads on here to point me in the right direction?
    Tuning Addict
    Jan 2015
    6,813
    Well I'm probably the only one on here who dials them in The way I do it isn't 100% correct but it gets it close enough to hand edit if need be. I actually had another member on here create a tool to calculate and apply the correction factor back to the map model and it works really nice for that. Having the VE and MAF dialed in is an absolute must and not just the areas where you're normally driving. The VE has to be completely dialed in and for all cam positions if using a variable cam. You can fail the MAF or use Cringer's tools for that. His newest VE tool is pretty dang nice and will get the VE really close with it's auto corrections if you haven't used it. I'm really looking forward to 2.0...
    You can shoot me an email for the other tool as it's not public.
    ~Greg Huggins~
