Results 21 to 40 of 46
Thread: 06 GTO L92 swap
  1. #21
    Sep 2023
    17
    Should I go back to the original map sensor and and put a tube piece one it to make it fit the ls3 intake?
  2. #22
    Aug 2006
    5BA8
    3,254
    No, just adjust the linear and offset for the map sensor you have in it now.
    EFI specialist
    email=[email protected]
  3. #23
    Sep 2023
    17
    Hey, I know its been awhile. I changed the setting on the MAF like you said still didnt start.
  4. #24
    7,649
    Can you post the most recent tune file so we can look at the changes you've made, or should we assume everything is right this time?
  5. #25
    Sep 2023
    17
    5.hpl5.hpl
    I have attached the scan from 2 days ago.
  6. #26
    Sep 2023
    17
    gto-02.hpt
    This is the tune.
  7. #27
    Aug 2006
    5BA8
    3,254
    It has a dead battery.
    Cranking RPM is 70ish. Voltage drops under 9 volts. Battery is most likely total junk. No tuning is gonna fix that. Before you even turn the key on it's 11.7 volts. Key on not cranking it's down to 9.6. Put a battery in it.
    EFI specialist
  8. #28
    Sep 2023
    17
    I had been cranking it for awhile. These are the other ones i did that night. Some of them I shot some starter fluid in it to get it to start.2.hpl3.hpl4.hpl
  9. #29
    7,649
    Power to the injectors? Is there signal to the injectors while cranking? Are the injectors spraying any fuel? Do they spray fuel if you pulse them manually?
    (still using LS2 injector data with LS3 parts is another thing, but we'll burn that bridge when we get to it)
  10. #30
    Sep 2023
    17
    When I did the noid light test I got no pulse
  11. #31
    Jan 2014
    SoCal
    1,565
    Reading through this and saw you said "I changed the setting on the MAF". Is that a typo? Did you mean to say MAP? The MAP settings were the ones that needed adjustment
  12. #32
    Aug 2006
    5BA8
    3,254
    That's a typical response. And BTW the 2 data log is the same thing. After just a couple seconds the cranking rpm drops below 100 and the battery voltage is 9.6ish. But lemme guess "that ain't it".
    EFI specialist
  13. #33
    Aug 2006
    5BA8
    3,254
    From log 2....
    EFI specialist
  14. #34
    Sep 2023
    17
    yes that was a typo I meant to say map
  15. #35
    Sep 2023
    17
    So i would get no pulse from the noid light test if the battery go to 9V?? I'll go buy another battery right now if thats the problem. Also just put the battery on charge
  16. #36
    Aug 2006
    5BA8
    3,254
    LOL it's the basis for everything. You can't start a car with a bad battery. Charging a bad battery does not fix a bad battery. You have to be able to charge and test a battery properly to even know if it's a good or bad battery.
    It's nothing complicated. You don't need to fix it by tooning. You can't fix it by tooning. It's basic auto 101.
    EFI specialist
  17. #37
    Sep 2023
    17
    I got the battery tested its good.
  18. #38
    Sep 2023
    17
    6.hpl
    I did this one after the charge.
  19. #39
    7,649
    When you first changed the VATS, did you do 'write entire'?
    Whenever the 2-bar OS accidentally got applied, did you do 'write entire'?
    When you un-did the 2-bar OS and went back to stock, did you do 'write entire'?
  20. #40
    Sep 2023
    17
    yes I did
