Results 1 to 4 of 4
Thread: Aftermarket scan tool suggestions
    Apr 2016
    331
    A need came up for me recently for a diagnostic scan tool (2016 GM car not supported by HPT), and am looking for suggestions. I have a tech2, but the car is too new and uses GDS2/MDMI. A friend recently bought a Launch X431 and is happy with it. I also see the brand Autel coming up a bit. Anyone have any input/suggestions?
    7,646
    No matter which one you pick, there will be something on one or more cars (or even whole makes) that it just won't do, or doesn't do right. Extremely common for the pros to need more than one scan tool for that reason. Also why it's extremely hard to give a recommendation for the one that will do everything you need. None of them will.
    13,565
    I have an Autel MS906Pro and I have a Launch 129E scan tool.
    Both work good but obviously the Autel can do about a million more things and is way faster.
    https://autel.com/us/product/maxisys-ms906-pro/
    Nov 2017
    1,466
    You need to seriously look at what functions do you need. TPMS, Key programming, Pass through programming, oscilloscope, etc. At least with Autel, it's a pretty good jump up to get one to add a function, or it's another device. I ended up with the Autel MS906BT and then ended up wishing I bought one that could handle pass through programming.
    You might want to also consider the TopDon stuff.
