I have a 1987 Trans Am with the following:
(from over 15 years ago)
383 stroker IIRC its just under 10:1
Comp Cams 272 / 272 .484
30lb/hr injectors
1.5 roller rockers
(In the last few weeks)
New fuel pump. Fuel pressure is near 60 PSI (for the few seconds it will run). It has a EFI connection 24x conversion timing cover and wheel, it has been converted to CNP / Distributor-less ignition. It runs a early 2000's DBC ECM
I cannot get it to stay running - It will light right off and then it sort of peters out after a few seconds, VATS is disabled. Sometimes it will restart right away, sometimes it won't. There are no engine management codes, just stuff I have not turned off yet (EVAP, EGR, etc.)
I don't have enough experience tuning something this far off the grid -
Any input would be greatly appreciate!
