nsterad of a big long story im going to try and just give facts to make it simple till the end here:
So we have a 60s chevy truck in the shop, It had a Holley harness and computer on it, well the computer went out for the 2nd time and owner wanted it gone. Brought it to us to do the work.
*It is a LSA stock motor with a cam and headers.
*Harness we ordered was a LSA harness and all parts needed, gas pedal,maf, map, o2s to all make it work.
*Computer was read and its saying it is a 2012 CTSV
*flashed for MAF tweak and wont start
*SOOOOOOO after trouble shooting for a day trying to figure out what happened we grabbed a computer off the shelf and put it in and it fired off, ran bad, no TB but it runs. This computer is a 2007 TBSS computer.( i cannot use this computer as it is locked out, its just kept for testing)
*So thinking the drivers in the computer got fried in the flash for some reason we got another new computer for it.
*downloaded the file, change injectors and maf info, flashed it, and no start still.
*Thinking again that we must have a issue on the truck, frying the ECM, we tried the 07 TBSS comp again and it fires off.
* order another computer, don't flash it, don't hook it up yet, send all info(and tunes) to HPT support for help to make sure and they said they see nothing wrong.
* we then make the harness a stand alone harness and take the truck out of the loop to make 100% sure its not the truck back feeding into the ECM or something during the flash and voltage drop and messing it up.( has alot of stuff running with IGN on)
*Now truck is stand alone, starting it with a start button even, no start. BUT will start and run on the 2007 TBSS comp still.
*Now we are kind of chasing our tails. We have a total of 3 e67s here all with 2012 CTSV OS and tunes in them, and now will fire off, no pop, no fart, nothing. Noid light shows nothing, no spark either
*The TBSS computer im pretty sure it just running in REP but it runs, the TB is different so obviously its in REP
*replaced Cam sensor with new also
* I get 150 RPM reading on the HPT scanner with ALL COMPUTERS when trying to start so Crank sensor is good on all
So anyone have any idea why a 2012 OS e67 wont run on this harness but a 07 TBSS will?
I was thinking cam sensor the whole time, but we have changed it out and checked the wiring. We are now looking into what wiring this harness it for. cause its not the same as the diagram of a 2011 ctsv we have here.....
