12639835 os on a 2011 chevy tahoe 5.3 6l80e needing a 6.2 segment swap file if anyone has one!
L94 or L9H?
im guessing l94 cause its the afm engine with vvt with flex fuel
im going to ask since were here already, reason im doing this is cause i already did a seg swap on this vehicle but after when trying to get on highway it went into limp mode and flagged the p0606 code and maybe thought i flagged the wrong compare in it but then i compared what i put in with what you sent and its exactly the same, any ideas?
Post your stock 5.3 file before the segment swap. Post the swapped file. Post a log file.
And maybe explain what work has been done and which parts from which vehicle/engine you used.
But, another cause can be segment swapping one of the HPT-accessible segments to one that's no longer compatible with the inaccessible ETC/TAC segments. Reverting the visible settings in the editor may not fix the part that's causing then to no longer work together, it could be background tables we don't have access to. Segment swaps are usually not the right solution to something straightforward like an engine swap from one LS to another LS.
so sadly i dont have the original file, it was brought to me already "swapped" ill still post it but this tahoe is bone stock, just a 6.2 swap came with dod and vvt
Still need a log file. The 'Details' tab in a log file is the only place (in HP Tuner-land, anyway) where the two TAC segment IDs can be read.
Do the tune files still have the vehicle's original VIN number?
As someone stated earlier, P0606 is most commonly caused by someone screwing with the ETC tables.
If you do a compare of these 2 files, the ETC desired throttle area tables are drastically different. The tables in the "old" file look like the stock tables for that ECU. The "new" file is not.
This is from the repository. All I would recommend doing is using it for reference. Copy over the ETC tables and try it.
EFI specialist
email=[email protected]
