Hi,
I've just done some logs with my C6 ZR1 and I'm wondering about the boost and therefore the power of the car.
At WOT, the boost is only 9psi (see the autobahn log).
I remember reading on corvetteforum that the 10.5 psi announced by GM was not often reached (we don't know where it's measured). And clearly, the advertised 647 hp aren't there.
My question: can the tune be modified to improve boost?
The car is stock, apart from a Tony Mamo Throttle body and a Corsa X-pipe (instead of the 2 extra cats added from 2012).
The tune is original: I've only calibrated the MAF in CL mode (no WB yet) and lowered the PE table by 3%. I haven't touched the torque management table or the boost control values.
A priori, there's no boost leak. I checked and slightly modified the blower bypass valve to make sure it was closed at WOT, and no change. No DTC nor CEL.
After all, maybe everything is normal and I'm a little too paranoid ?
C6 ZR1 10 SEPTEMBRE 2023 BIS.hpl
