Need Advice in tuning from 93OCt to 100OCT
Hello ... I've been running this 93 tune on a boosted Boss 302 for about 2 years already and have been happy with it (no Knock Retard recorded at all). I have brought it to the drag strip for test & tune for 2 seasons now and was able to do 10.6 in a 1/4 mile as my PB at full weight. Now I wanted to try a 100OCT fuel tune to see if I can squeeze a little bit more to be able make it to low 10's, of course by also doing it safer. I know there is a lot that I can do before touching the tune e.g. driver mod, weight reduction, etc. Question is, what parameters do I need to change, Stoichiometry value ... and more ? Do I only need to change my WOT fueling/Spark area or I have to do everything from scratch? What are the ramifications if I only do the WOT part? Below are the vehicle specs:
2013 Boss 302
Whipple Gen 4/2.9L
3.625 pulley @ 10PSI
1 7/8 Kooks Catless headers
93OCT tune
BAP
ID1050 Injectors
(70% average Injector Duty max at WOT / 0.76 AFR @ 7500rpm)
18 Deg timing up top (Knock sensors incrementally adding timing during acceleration is the way I tuned it)
Drag Times
10.6s @ 128 mph 1/4 mile
Reaction Time = 1.54
DA is about 3200ft
Any advise is greatly appreciated. I can post the file if needed. Thanks
