Is there any more risk writing tunes or files in with an MPVI1 vs the newer MPVI3? looking at buying an older mpvi1 to do some bench work with, but I do alot of newer vehicles, and dont wanna buy a multi thousand dollar ECU.
I think one thread is good enough, but anyways.
I still use the MPVI, had it since like 2012. I have no current worries with it for what I need it for. I can't use it on a ton of new new vehicles because I use older software on it and will not be upgrading this device to anything newer than what I have now.
Ok, do you need an mpvi1 to use with older versions? I still have 4.8.7, but cant get my mpvi3 to connect to it. Do i need an mpvi1? And if so, where can i get one?
MPVI3 was introduced at the same time as v5.0 so 5.0 or newer is necessary for MPVI3.
I still have a MPVI1 Works fine.
Anyone remember the Hptuners cables with DB9 serial ?
Tuner at PCMofnc.com
